跳转到主内容
The 5th generation of the Moto E Play smartphones, released in July 2018. Model numbers XT1921
20 个问题 查看全部
Charging port pins damaged?
My phone was only charging when I pushed the charger in as hard as I could. I cleaned out the port with a toothpick, but now it's very finicky. It will only charge in USB mode instead of AC, and it's much too slow even after I replaced the battery. Sometimes I have to twist or push the charger around to get it to connect at all. I think the pins are damaged somehow, but they are as straight and clean as I can get them. Other micro usb ports I've compared it to look much sturdier, but this one has very thin, flimsy pins!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
I assume you are talking about a micro USB port. I have had issues with some devices. It is very difficult to tweak those pins. You said it works OK with a USB charger vs the AC charger. That would indicat the AC has a separate cable. Therefore it may be a problem with the AC connector and not the phone connector.
这个答案有帮助吗?
得分 2
2条评论:
Some good comments here...
All USB charging is done with DC.
Whether its a USB cable in a power bank or a USB cable into an AC adapter.
Asking Bekahoot;
What is the difference between a "USB charger" and a USB "AC charger?
I'm sorry I'm European I don't get the difference.
完成的
In my thinking an "AC charger" is one that plugs into the mains. A "USB Charger" would be plugged into a std USB port as on a computer.
完成的
添加一条评论
Bekahoot.
We need to establish where exactly the problem is in the power supply chain?
If you follow @craiglloyd Motorola Moto E5 Play Screen Replacement guide from steps 4 as far as step 11.
  • The problem is either going to be the in the USB charge connector OR with the motherboard flex to the so called “daughter board”
  • The intermittent / Slow charge could be an intermittent connection (increased contact resistance) on the motherboard flex. Sometimes carefully opening and closing the connection may have a positive result.
  • The daughter board can be removed from step 11 to step 12 where it can be inspected visually.
  • Bear in mind the USB port is an electro/mechanical component subject to repeated use, stresses and strains and can and will wear out eventually.
  • If its questionable it seems like a servicable part I’d replace it
这个答案有帮助吗?
得分 1
添加一条评论
I am as we speak messing with my lovely port ,this ain't my first rodeo guys and gals,its my second. Thankfully it don't seem as bad as the first time I can say though it is not hard to fix. My sons gf changed mine out with another one in like 5 minutes I was amazed(thought that might give someone some hope out there). Seems this time its just the lil tiny pins, if I knew how the pesky lil sh*ts looked normal I might be able to do a quick fix hope I helped keep hope alive
这个答案有帮助吗?
得分 0
1条评论:
Compare the pins to a good cable. It is very difficult to reform those pins. Messing them up with too much reform action is easy. Check for bad solder connections if it is on a PCB. I have had that problem with some devices.
完成的
添加一条评论
添加你的答案
Bekahoot 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 15
总计 1,226
