Released March 2019, identified by model number SM-A305FZRFINS
jenniferpinnell1973 @darkangel73
声誉积分: 1
发帖于: 2022年1月18日
Why is my A30 stuck in a loop.
这是一个好问题吗?
4条评论:
Hello.
Have you tried to force your phone to reboot..?
I think you need to hold the power down for 10 seconds or something.
When its off you need to wait a few seconds and then hold the power button again until it wakes up.
I'm not sure if this is a quick fix hack or is there some longer / better solution
由 Stephen Gilsenan 完成的 2022年1月18日
I've tried that. Stays stuck in its loop. I've tried the boot menu. Stays stuck... But thank you.
由 jenniferpinnell1973 完成的 2022年1月18日
Ok.. I did find something that was related to - Samsung Galaxy A30 keeps restarting, Freezing Problem and Closed Unexpectedly | How to Fix? -
if you search that you may find a suitable answer
@eureka is this what you were relating to :https://hrdreset.com/samsung-galaxy-a30-... ?
It is okay to add links into your comment or even to your answer. If iRobot "bites" again let us know :-)
由 oldturkey03 完成的 2022年1月18日
bill @ruggb
声誉积分: 4千
3
could be a bad battery or one with low charge. It may be shutting down after it tests the battery charge and finds it is below the shutoff level.
这个答案有帮助吗?
1条评论:
Not the battery, does with full charge. Thank you for your help.
Erick Mathias @erickmathias
发帖于: 2023年3月13日
Why does my A30 just keep switching on and off to the Samsung?
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 573
Hello.
由 oldturkey03 完成的
