跳转到主内容
The Sony XBR-65X850D is a 65-inch LCD Ultra HD TV with an LED backlight and 2160p resolution. Released in 2016. Model number: XBR-65X850D.
27 个问题 查看全部
Why is my TV screen dark upon startup, fine after warm up/resetting?
The TV in question is a sony xbr-65x850e.
About a year ago I noticed the screen is dim/dark, not black upon starting up. After I leave the TV on for 10 minutes and restarting the TV, it will appear normal.
The warm-up period has progressively taken longer over time. Early on, I did not have to leave the TV on for very long but now I have to leave it on for 40+ minutes before it restarts to normal, bright picture?
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
TWP could be a cold solder joint or a failing component. Remove the back cover (unplug your TV of course) and check the boards for any obvious damage (don’t touch anything just yet. Capacitors may still be charged and could zap you). Check for anything that might look “odd”. You can always post images with your QUESTION for clarification. Measure the output voltage from the power board to the backlight LED’s when you just start up your TV and then measure it again when it is warmed up and the picture is showing. See if there is a variance. The other issue could be that backlight itself but check the voltages first.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
TWP 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 151
