跳转到主内容
加入维修社区 - 创建账户
Repair and service information related to the ResMed AirSense 10 CPAP machine. Also known as the ResMed Air10.
My unit is making a loud noise when I breathe in and out
How can I fix the loud noise when breathe in and out?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
3条评论
When I breathe, my machine makes a squealing sound. It appears to be coming from the two seals that compress when the humidifier chamber is attached.
完成的
The water is gone in three hrs in well and no leakes in well. I have to refill every night .
完成的
I’m not a doctor, though I have been treated 30 years now for Sleep Apnea. I pretty much been through it all.
It is my opinion, you are sleeping still with your mouth open. They do make chin straps , to attach to one’s headgear, also you may want to try the nasal pillows, or what is called a full face mask. It actually just covers your nose and mouth. Those are what I’m familiar with, surely there may be more options !
Good Luck,
Sherwood
完成的
添加一条评论
8个答案
最有帮助的答案
I also experienced this. A sound from within the machine, a sort of wheezing sound that was apparent as I breathed in and out. It was a disturbing sound not having to do with an air leak from the hose, mask, or water tank, as I checked these possibilities first. I discovered the sound was coming from the motor itself. In my case, the motor in my machine was just five years old. I was able to replace the motor quite easily with the aid of a couple of YouTube instructional videos which were easy to find. I was able to purchase a replacement motor which I found on that large online shopping site. I believe it cost $129.00, and it arrived the very next day after I ordered it. I believe that just about anyone can replace their motor with the aid of an instructional video for which there are several on YouTube.
这个答案有帮助吗?
得分 10
3条评论:
Hello, could you send the link for delivering of the motor? I think, my problem is like yours.
完成的
Hi, so has this fixed the loudish sound while breathing and exhaling.
完成的
Just replaced my motor using a guide here. The sound disappeared with the instal of the new motor. Here is the one i bought: https://a.co/d/bWRwCbs
Here is the guide I followed(please make sure to read all comments and the guide thoroughly before starting): ResMed AirSense 10 Pump Motor Replacement
完成的
添加一条评论
@rdb88385 sounds like a pressure related issue. Double check your device to see if it is related to the recent CPAP recall. If so you want to contact the company and get directions from that. If it is not, then I would still suggest that you contact ResMed (or your local DME company as well as your health care provider) and see if they can guide you. You are obviously using/needing it and we all want you to stay well
这个答案有帮助吗?
得分 3
添加一条评论
Re the squealing noises- That’s a definite problem with Resmed machines. I put a tiny smear of Vaseline at the back of the humidifier where it meets the silicon seals. Every so often I use a baby wipe or something similar to clean it off the seals and humidifier then reapply. That’s been working for me for over two years now. You can put some Vaseline around the edges too of the noises persist. I hope that helps Rockie.
这个答案有帮助吗?
得分 3
6条评论:
Edwina! THANK YOU! This helped a lot. It didn’t take away the sound completely but it certainly helped reduce it significantly! I couldn’t sleep all night! 🥹
完成的
I have tried that as well as pulling my humidifier out during non use to avoid constantly compressing the seal. Both your comment and latter action above have helped the problem. I have a new part on the way. YouTube has a video on how to install the new seal.
完成的
My c-pap machine is making loud noises when I put it on . I’ve changed the head gear, heating hose, water chamber and air filter. The noise is coming from the machine please help
完成的
Just replaced my motor using a guide here. The sound disappeared with the instal of the new motor. Here is the one i bought: https://a.co/d/fmJu84y
完成的
My resmed 29 airflow bibap make a noise when ii inhale that i cant even fall asleeo
完成的
显示更多的1条评论
添加一条评论
The noise is generated due to the blower assembly check the assembly .
这个答案有帮助吗?
得分 2
添加一条评论
Tighten the strap system as it shouldn't make noise and if it starts whistling put a small bottle of water on the door to the water tank. To stop the face farts tie a handkerchief over the gasket so it covers it and the gasket will last YEARS.
这个答案有帮助吗?
得分 0
1条评论:
Face farts - best thing I have read in a long time lol
完成的
添加一条评论
may be water condensed in your air tubing. Sounds loud. drain water if present.
这个答案有帮助吗?
得分 0
添加一条评论
We had two brand new machines with this problem. We finally bought new ones of the latest model. Totally silent.
Resmed would not admit to any problems. My therapist says this is not uncommon-- fix is to replace motor or replace total unit.
这个答案有帮助吗?
得分 0
添加一条评论
Defective cpap unit is often the case. Motor is bad. Replaced the unit and no more problems. More common than you would think.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
roger bailey 将永远感激不已
浏览统计数据:
过去 24 小时: 25
过去 7 天: 147
过去 30 天: 790
总计 27,404
