跳转到主内容
加入维修社区 - 创建账户
Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
Display Temp Sensor Board
I am trying to fix an iMac 2010 EMC 2389 Display but the wires to the temp sensor board on the rear of the display have become disconnected. I can solder them back easy enough, but I cant seem to find the proper wiring diagram / schematic to ensure the correct polarity.
The board front has the markings ICT-Lanto and the rear has
HF
94V_O DS1
E220742
marked on it. Can anyone help with which wire to solder to which output? Will post a photo.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Fxguy1 the most inward connection on your logic boards temp sensor connector is the Positive and it is wire number one on your sensor board. The outer one is the Negative and connects to point number 2 on your board.
这个答案有帮助吗?
得分 2
1条评论:
@Fxguy1 I converted your comment to a separate question. That way you will get the right answer and lots of advise on how to further troubleshoot if necessary
完成的
添加一条评论
添加你的答案
Fxguy1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 151
