跳转到主内容
加入维修社区 - 创建账户
Whirlpool(惠而浦)品牌顶开式和前开式洗衣机的维修指南与支持。
Whirlpool washer fault/error code confusion
Model # WTW4816FW2 Sensor light blinking. I cleared machine then entered diagnostic phase and tried to determine fault/error. When I get to the point where the fault/error can be read, all I get is the sensor light blinking. All other lights remain off even if I go through the last 4 fault codes. Anyone know what the sensor light blinking in the fault code mode means? Thanks, in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
7条评论
sir no light blink spin lagane par wash on ho jata hai
由完成的 分享
Hi @zis0786,
What is the model number of the washer?
由完成的 分享
I’m got a code the sensor light an spin then spin am done what part do I need
由完成的 分享
All of the lights on the machine are lit, and I cannot enter into the diagnostic mode
由完成的 分享
@thomasgiardino
What is the model number of the washing machine?
Have you tried unplugging the power to the machine for about 5 minutes and then plugging it back in again to see if this resets the machine?
由完成的 分享
显示更多的2条评论
添加一条评论
4个答案
最有帮助的答案
Hi @donley,
What is the problem with the washer?
In diagnostic mode a blinking sensing light only, indicates a No fault condition See F0 E0 code in 2nd image below and description of how the lights are interpreted in the 1st image below
F0 = sensing light on (F) + no other lights (0)
E0 = sensing light off (E) + no other lights (0)
So the blink pattern for an F0 E0 code would be that only the sensing light should be on for 0.5 seconds in every 2.5 seconds or on twice in 5 seconds to make it easier to tell
Maybe check that the other lights - wash, rinse, spin and done, all work when performing the UI Test mode - see p.4 & 5 in the tech sheet, just in case one of these is faulty.
Here are some images from the tech sheet for your model, showing the error codes and how they’re interpreted.
(click on images to enlarge)
这个答案有帮助吗?
得分 7
11条评论:
Thank you immensly. I re-did the diagnostic testing based on the instructions. When I turn the dial in the diagnostic sequence so that only the DONE light is lit (to enter the fault/error procedure), then push start, I get all lights blinking followed by no lights blinking. I am assuming this is a F-12 E-0 result. If so, I can not seem to find an F-12 explanation of what is wrong. Thank you, again. My home was in the direct line of fire of the tornado a few weeks ago. Tons of repair and I am just not getting to the washer.
由完成的 分享
@donley
All lights blinking = F15 i.e. sensing = F then wash = 8 + rinse = 4 + spin = 2+ done =1. As all are on it adds up to 15.
Then no lights = E0
There is also no F15 E0 code so I'm wondering if it is the control board.
if it failed because of the tornado and the washer was plugged in even if it was not operating at the time then if there were power outages, the control board may have been damaged.
It certainly seems like the software has been corrupted as it is giving non existent error codes or is not starting.
Try and see if you can reset it.
Also try the Main Control Troubleshooting test on p.12 of the tech sheet.
由完成的 分享
I have error codes for Sensor and Wash (not flashing) and Done flashing.
What does it mean please or the codes that I need to find the product I need to fix it.
由完成的 分享
@Julia Cummins
由完成的 分享
Whirlpool washer no error codes but will not cycle through, stuck in sensing mode. HELP!
由完成的 分享
显示更多的6条评论
添加一条评论
Hi @toddsaunde90462
If you washer is the same model as the one in the question, to check what the problem is when there's an F2 E1 error code, go to p.16 Test #4 Console and Indicators in the tech sheet linked in the Most Helpful Answer above, to see what to do.
这个答案有帮助吗?
得分 1
添加一条评论
Hi @thomasgiardino
Check the status of the diagnostic LED on the control board - see p.2 of the tech sheet and if it is off, go to TEST #1: Main Control on p.12 to see what to check,
这个答案有帮助吗?
得分 1
添加一条评论
Hi @toni8823,
An F2 E2 error code in your model indicates a loss of communication between the main control board and the UI/Encoder (user interface) board.
By turning off the power and then turning it back on again you are effectively resetting the boards.
Since you haven't said what the two technicians tried to do to fix the problem, initially disconnect the power to the washer and then gain access to the control panel and check the cable connection between the two boards to make sure that they're secure and also not corroded etc, Check both ends, i.e. board in face of control panel and main control board in the body of the control panel.
Here's a video that may help. The main control board connection can be seen at 1:44 minutes into the video.
If everything appears to be OK another option is to replace the boards, i.e. main control board (part # W11513246) and UI/encoder board (part # W11481116), one at a time to see if this resolves the problem.
The links are just to show the Whirlpool part number for the two boards in your washer. Perhaps find a supplier that accepts returns so as to minimize the cost to you if changing one board doesn't fix the problem.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
tim 将永远感激不已
浏览统计数据:
过去 24 小时: 19
过去 7 天: 132
过去 30 天: 802
总计 48,205
