black screen stuck in bios mode
cursor keeps blinking upper left hand corner of screen
Your computer is not finding the boot drive. Take a look in the BIOS.
Press F10 when the HP Logo screen appears to get into the BIOS menu.
See what hard drive is listed. Select it as your boot device. If one is there and it still does load Windows then either the drive itself is damaged or more likely Windows is corrupted. Does the Windows loading screen come up at all, even for a short time? If it does shut down 2 or 3 time when that screen appears with the power button. Windows 10 will open into the Advanced Start-up environment
While in the Advanced start-up environment, use the following steps to use Start-up Repair:
If the above doesn’t help do the same as above but this time select “System Restore” from the “Advanced Options?”
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 18
总计 949
2条评论
What Operating System do you use with this computer? Have you tried pressing the BIOS menu key?
由 Andrew S 完成的
Cort Christiansen BIOS mode or BIOS screen. Not sure about the BIOS mode but it should not be a black screen. This sounds like your computer is not finding it's operating system.
由 oldturkey03 完成的
