跳转到主内容
加入维修社区 - 创建账户
树莓派是由英国树莓派基金会研发的信用卡大小单板计算机(SBC),于2012年首次发布。
Raspberry pi 4 Not Booting Solid Red One Green Flash
Hello I have a raspberry pi 4 and after it was lying for some time in a drawer I decided to use it for something and it doesn't work. I'm sure it used to work before and even though it was just lying in a drawer it just stopped working. When I plug it in the red led is solid and green led blinks for maybe half a second. I tried multiple SD cards (known good ones) and multiple power supplies (also connected it to laboratory power supply to make just to make sure but the same problem, also it's constantly drawin like 300ma).
There is no display over HDMI with or without the SD card. Also pi is acting the same no matter if the card is plugged in or not (same as described before red light one short green blink when connecting power). All voltages seem to be present but there is no power on the USB ports even though there is 5v at GPIO, the SD card and the ethernet seem to be getting powered as well. SD card slot is in good shape as well.
https://imgur.com/a/x2ZYtXS images of the pi
Thanks for help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Did you ever find out what was wrong? I have a rpi4b with the same problem.
完成的
添加一条评论
1个答案
最有帮助的答案
Hi Rej,
Some of the info I’ve been able to find out online about this suggests that for older Pi’s (before the 4) a solid red LED with a single green flash is related to an incorrect SD card image or the wrong size card (4GB or bigger seems to be required). For the Pi 4 though, this doesn’t seem to be a known error code. I would recommend verifying the version of the Pi that you have is a Pi 4, and then trying to create a fresh SD card following this guide.
If this doesn’t work, it’s possible that there’s a hardware problem with the Pi. Take a look inside the MicroSD card slot to see if anything is stuck in there. Otherwise, an ESD event could have killed it sometime in storage.
这个答案有帮助吗?
得分 2
4条评论:
As i said SD card slot is okay I've already done what the tutorial says I've tried 2 64gb SD cards and none of them worked. Thanks for reply
完成的
i bought new RPi4 8GB. Same problem. No green light. only solid red light. the sd card is working very well with my RPi 4GB. I have tried another SD card also. 32 GB, 64 GB all tried, nothing worked.
完成的
@Praphulla Chaudhari Are you using the card from the 4gb pi in the 8gb pi? When I did this it didn't work, I had to flash the card again with the same iso as previous.
I presume at initial config the pi stores the specs of the board, when this changes, pi just says no.
完成的
Very possibly a static event, I'm sure the pi wasn't in the drawer all alone.
I know it isn't much use now but it's a lesson we all learn sometime in life... Anti static bags save lives ;)
完成的
添加一条评论
添加你的答案
Rej Tan 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 14
过去 30 天: 82
总计 8,737
