跳转到主内容
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
20 个问题 查看全部
Replacement iPad 5 Home Button doesn't fit replacement screen properly
In the process of replacing the screen of my iPad 5, I tore the home button cable. Ordered both the screen and button from iFixit, yet the button does not seem to sit properly in the screen, as if the hole is too small. Is it expected to fit in the hole or “float” on the backside?
I also ordered a replacement home button bracket, but it slightly differs from the original as there isn’t a little metal “button” on the inside that appears to be pressed against the center actuator of the button.
Update (01/07/2022)
It appears to be the glass as the original home button won’t fit into the glass either but the new home button WILL fit into the original glass. I am going to assume that I need an RMA, but will wait to see if anyone else chimes in or has any recommendations.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would RMA sounds defective
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sean 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 53
