跳转到主内容
Repair guides and support for your Toshiba TV.
193 个问题 查看全部
TV Turns on but no picture on screen
Toshiba Model - 43U2963DB 43 Smart 4K Ultra HD HDR LED TV
Was watching tv yesterday and tried to exit app and screen went black. Now tv turns on and off but screen stays blank. Tried unplugging it and leaving it 60 seconds - no luck. And saw advise to unplug and hold down power button on tv but I can’t find one on this model - unless I’m missing it.
TV only a year and half old and been mounted on wall ever since I got it so hasn’t been knocked or damaged. And I only use it as smart tv so no issues with hdmi cables or other connections.
Any help would be appreciated. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
@bhwo in a darkened room and with the TV on shine a flashlight beam at an angle against the screen. See if you can make out shapes/silhouettes etc. If so, it is your backlight that has failed. Also, let us know if you have audio. After that you want to remove the back from your TV and check the boards. Measure the standby voltage from your power board on the main board connector. Let us know what you find out. Also, it might help if you post some good pictures of the boards with your QUESTION. That way we can see what you see. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Beth 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 45
总计 448
