跳转到主内容
加入维修社区 - 创建账户
Google Pixel 2 是 Google 的第二款旗舰手机,发布于 2017 年 10 月 17 日。该手机配备 5 英寸 AMOLED 显示屏,有 64 GB 或 128 GB 存储版本可选。它有三种颜色:纯粹黑 (Just Black)、清晰白 (Clearly White) 和有点蓝 (Kinda Blue)。
Pixel 2 stopped charging.
I went to charge my pixel and thought I seen a small shock when I plugged it in. Now it won't charge or turn on. Could this just be a battery issue or is it a bigger problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
If the battery is dead that could be why it’s not turning on, the shock you seen is probably the charging port board so it would need replaced and that’s the only way to check you haven’t fried something on the motherboard
这个答案有帮助吗?
得分 1
1条评论:
The phone was not dead, I was pluging it in because it was at 20% battery. But as soon as I seen the little shock the phone went dead and no matter what cord I used it would not charge. I tried all my cords and even tested the Cords on other phone that use the same type. I also tried my car charger and nothing. Once it went dead it has never come back on.
由完成的
添加一条评论
Before you go tear it apart its best to check the charge port it could be full of lint or other debris. You can sometimes clear it just with compressed air but if the debris is packed in tight it may require you to clear it with a pic. use a plastic or wooden pick not metal as metal can damage the outlet . Dont pry on the center as it can be broke off with enough force and then you would be in a bigger issue.
There could also be bigger issues such as a bad battery , or a bad charge port
This might help Google Pixel XL 子板更换
这个答案有帮助吗?
得分 1
1条评论:
由完成的
添加一条评论
添加你的答案
Tina Andrews 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 814
