跳转到主内容
加入维修社区 - 创建账户
电脑和家庭中常见及不常见的电缆。
HDMI Cable End Needs Replacement
I have a damaged HDMI cable end that needs to be replaced/ repaired. The cable is behind walls and is a very long run 100ft +/- I’m trying to find out if the damaged end can be replaced.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
HDMI head replacement
完成的
添加一条评论
2个答案
最有帮助的答案
Hi @elmo1234 ,
Hopefully there is enough slack in the cable to allow for a new connector to be wired in.
Here’s a video that shows how to wire a HDMI connector that may help.
It also may depend on what type of HDMI connector is being used.
Connectors are also available from here and here (supplier examples only)
if doing this yourself seems too daunting contact a reputable, professional electrician who also does data, TV wiring, security installations etc and ask for a quote
这个答案有帮助吗?
得分 2
添加一条评论
此回答最初是针对另一个问题
Hi @elmo1234
Referrals are too subjective and are usually not acceptable on ifixit as it is mainly a DIY forum where people can offer advice on what you can do to fix the problem yourself.
Here’s a link to some services in your area who may be able to help you.
Check their reviews and then go with the one you prefer.
Moderator.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Wayne 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 47
总计 6,644
