跳转到主内容
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
Need to upgrade applications
hi @mayer! iʻm on a previously used/refurbished mbp 9,1, 16GB, 1TB SSD, so definitely third party additions. Iʻm currently running Sierra 10.12.6, but now i am falling off backward compatibility for various software that i need for work.
1) is upgrading to 10.13.6 likely to give me problems as the OP experienced,
2) likewise for 10.14 or 10.15,
in general, will i be ok on this machine upgrading to new OS? i see refurbished 9,1ʻs sold on the market with 10.14, but donʻt know if they have problems.
thanks so much!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Your 2012 15" MacBook Pro should stay at Sierra (10.12.6) as being the best due to the differences between the older HFS+ and newer APFS file systems. The older HHFS+ runs better on SATA drives.
If you must, I would go to Mojave (10.14.6) ands no farther or High Sierra (APFS beta). Catalina won't run older 16/32bit apps and add-on's. You need 64-bit apps/add-ons so make sure you don't have any dependancies on the older 16/32bit. Catalina (10.15.x) is as high as you can go with this system.
But your biggest issue is the HD SATA cable! Your Hard Drive Cable Is A Ticking Time Bomb I strongly recommend replacing it and applying the tape as well. MacBook Pro 15" Unibody (Mid 2012) Hard Drive Cable & MacBook Pro 15" Unibody Mid 2012 Hard Drive/IR Sensor Cable Replacement
Replace a damaged cable connecting the hard drive to the logic board in your laptop.图片
产品
$19.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kahana 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 67
