Cant press play on xbox one game Mr.funnys toy shop?
Cant press play..on xbox..to play Mr funnys toy shop
So for some reason the play button is not working when your trying to play the roblox game Mr. Funny’s Toy Shop:
Since this is a new xbox, and new controller, then that shouldn’t be the problem I’m suggesting that it might be a glitch since its occurring with other games. I recommend resetting your Xbox, here’s a video that might help: https://youtu.be/U8T9CMqmmK0?t=7
If the problem is still occuring, I then suggest to reset the actual controller, here’s a video that might help: https://youtu.be/dRSvLSK9Tc8?t=17
Since you tried all the buttons, this is actually a pretty common glitch, here it happens to a guy where he try’s to play Halo and he also shows how to fix this problem: https://youtu.be/uTV5WqMY20g?t=10
You could also check the Xbox status page. If you see any services with alerts, expand the service, scroll down to Notifications, and sign in to receive a message when the service is up and running again. Or you could also restart your PC. On your PC, press the Windows button, then select the Power button, then Restart. If the PC appears to be frozen, press and hold the Power key on the device for 10 seconds, until the PC turns off. After it shuts down, press the Power key to restart.
If the problem still occurs, I suggest you look through the manuals and Contact Xbox for support at: https://support.xbox.com/en-US/help/hard...
Hope this helps :)
这个答案有帮助吗?
Some roblox games do this I think it's because roblox is primarily a PC game so the game was designed to be used with a mouse
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 1,379
8条评论
Hi Chris. Could you provide some more information regarding this?
由 koppie007 完成的
Grandson has new xbox.on some games..including above one..where it says ‘play ‘ on screen..u can't actually click on the word to play it. Tried ALL the buttons..even in different patterns
由 Chris 完成的
@chriscad Did you also tried a other controller? Looks like it's software related (could also be a hard disk issue). Is it modded?
由 koppie007 完成的
Brand new.came with one controller. Font think it's a fault..just can't figure it out.thanks anyway.happy new yr
由 Chris 完成的
Looks like a software fault yeah. Perhaps a mod got stuck (if it's modded).
由 koppie007 完成的
显示更多的3条评论
