跳转到主内容
加入维修社区 - 创建账户
XP-410 采用了最新的无线标准,并支持 Wi-Fi Direct1。此外,它还支持 Apple® AirPrint™ 和 Google Cloud Print™。内置读卡器、2.5 英寸 LCD 显示屏和便捷的触摸面板,无需电脑即可轻松打印无边距的个性化照片。
How can I fix error code 0x9A
I have an Epson XP-610 that was in storage for 2-3 years. I pulled it out to see if it still works, to give to my uncle. Everything worked but it wouldn’t print - every sheet came out blank. After researching why it wasn’t printing, I determined the printer block was clogged with dried ink. Researched that and followed the procedure to put paper towel under the printer head and force water through the ink ports. Too cumbersome and time consuming. Followed instructions on how to remove the printhead and soak it in warm water to remove the ink. Took about 45 minutes to get clear water. Reinstalled the print head and when I turn on the power it says “Internal problem. Turn the power off. Error code 0x9A. Followed Epson website recommendations but nothing works. Followed suggestions made on internet. Still nothing works.
Is there any way to determine what might be causing the error? I’m pretty sure I got the wire cable back the way it’s supposed to be. Don’t know where else to look. I’m not going to take it in because it’s not worth the cost to have someone fix it. I’d like to take it on because I have nothing else to do and like the challenge.
Any suggestions appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Disregard. I purchased a new printer.
这个答案有帮助吗?
得分 0
添加一条评论
Disregard. Purchased new printer
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jack Anderson 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 28
总计 1,294
