跳转到主内容
加入维修社区 - 创建账户
发布于 2019 年 4 月。型号:SP315-51-757C。Acer 推出的全旋转触摸屏笔记本电脑。
Why do my computer lights not flash?
Both my blue and orange lights on my Spin 3 aren’t flashing anymore. Usually they flash. I had some water damage with it, so that might be the problem. I have reset the battery many times now and that makes the orange light turn on, but the laptop screen doesn’t. I don’t here any fan noises either. The water spilled on the front of my laptop and not the back of it (I was on a plane and the water bottle was loosened) so that might be an advantage. I see dust and it looks dry so that might be good.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @mangoedu,
Seems like the water has damaged something. The impurities in water creates circuit paths for the electricity which may not be in the operating design of the laptop and could damage components. It also causes corrosion to occur adding to the problem.
Do not try to turn on or charge the laptop and disconnect the battery as soon as possible so as to minimize any further damage.
There is always power somewhere on the motherboard even when the laptop is switched off. The power button is not a power isolating switch. Its function is to signal the intentions of the user.
Since there is minimal function you may have to get the schematics (supplier example only) for the laptop’s motherboard (is it a Pegatron ST5DB?) to find out where the problem is.
Start at the power input and work forward.
You may have to contact a reputable, professional laptop repair service if you are unfamiliar with doing board level fault finding and repair using schematic diagrams.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dog 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 266
