跳转到主内容
加入维修社区 - 创建账户
三星 GT-E2120 发布于 2009 年 9 月,配备内置 FM 收音机天线以及蓝牙无线连接功能。
Why it is not continue starting
it start for a while the phone models appear and then turn off again..
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
最有帮助的答案
The model of my phone is GT-E2120 as mentioned here,my phone is not getting switched on,i don't know why. It was initially getting switched off for every five minutes but now it has got switched off completely and I have tried switching it on but it's not getting switched on and i have also tried plugging in the charger but there is no difference,it remains to be switched off.Am not understanding what the problem is,how do i fix this?please help..
这个答案有帮助吗?
得分 1
2条评论:
So I know how to do this first connected to a PC and restore some things or if it doesn't work try going to the repair shop so they can repair your phone and work back to normal if it doesn't work still call Samsung
由完成的
I usually have the same phone but it works properly :)
由完成的
添加一条评论
This sounds like a case of dead battery. Plug your phone into the charger and try to turn it on. Does it? If it does, you need a new battery. If that doesn't work, try doing a hard reset. You will lose all of your saved data, but it may recover the phone.
这个答案有帮助吗?
得分 0
添加一条评论
it's a common problem. you have to update firmware
http://www.symbianize.com/showthread.php...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
nelson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 4,255
