跳转到主内容
加入维修社区 - 创建账户
Sony Xperia XZ1 Compact 是索尼于 2017 年 10 月发布的一款紧凑型旗舰 Android 智能手机。
Can I replace the gps module?
My gps is not working properly. I found online that most users think that it is a hardware issue. I cannot find a guid how to replace the module / repair it. Is it possible to do at all?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
What exactly is going on with the GPS? If it is a hardware fault then that may be a bit more difficult to repair. Aside from the antenna, anything that controls GPS is actually a chip on the board. So it’s not something that can be swapped in easily like a battery or a camera. Unless the antenna is to blame. Which may even be integrated into another part.
It can likely be done. But antenna issues aside, to do so you would need experience microsoldering, and access to known good parts. It may not even be the actual component which controls GPS, it could be something mucking up communication signals to other components. Or something causing an issue with power to the chip. It may me difficult to isolate.
Because it is so complex, that’s probably why you aren’t seeing a clear cut guide on how to repair. If you can get to the internals of the phone, post some detailed pictures, which might help to find specific faults.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Pieter 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 14
过去 30 天: 35
总计 1,024
