跳转到主内容
加入维修社区 - 创建账户
Flip Mino HD 于 2010 年发布,是一款口袋大小的摄像机,拥有 4 GB 存储容量和一小时的拍摄时间。
Replacement for Flip out USB
Hi there, my Flip Mino HD has a damaged ribbon cable for the USB on the camcorder, I can no longer charge it without the usb. If I can fix the ribbon cable how would I do that, If I need to buy the part where can I buy it from? All help would be appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You need to find out how many wires are in it than order a roll of flat ribbon cable from Amazon.
https://www.amazon.com/s?k=flat+ribbon+c...
这个答案有帮助吗?
得分 1
9条评论:
I can’t find the right one and the cable is physically attached to the flip out usb of the camcorder.
由完成的 分享
@TechVid How many wires is in the ribbon?
由完成的 分享
Alao a picture of that connection will help but it's probably just soldered. The wire can be split apart and soldered into place.
由完成的 分享
It is a flat flex cable and I am not sure how to do micro soldering nor do I own a soldering iron
由完成的 分享
Is it true that I can cut the rest of the cable, scratch a little bit of the torn side of the cable until the connectors are showing on both sides of the torn cable and tape them together with both sides touching? Also thanks for not telling me to get a new camcorder, the camcorder is special to me.
由完成的 分享
显示更多的4条评论
添加一条评论
添加你的答案
TechVid 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 16
总计 500
