跳转到主内容
Repair guides and support for read-only memory cartridges used in Game Boy, Game Boy Advance, and other handheld nintendo consoles.
9 个问题 查看全部
Is this cartridge even worth fixing?
Recently my copy of Super Mario Land for the Gameboy stopped working. I opened it up, tested around with a multimeter, and the problem was obvious enough.
I don’t know how I’d go about fixing this without damaging the board as I’m fairly inexperienced, and its an inexpensive game, so maybe its not even worth trying?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
@o0mcnugget0o that is a tough one to answer. The repair is actually straight forward. Use a scalpel and remove some of the green mask from the copper traces at the end and the beginning of where the “fracture” is. Then solder a thin jumper wire across to reconnect the trace. The trouble for you might be the soldering. Maybe you have somebody that could do that for you. I would at least try. Remember it is an “inexpensive” game but still something that would end up in the landfill and thus create more waste, which we really don’t need. Best of luck and let us know how it works out.
这个答案有帮助吗?
得分 1
2条评论:
Thanks! I tried out holding the copper wire in with electrical tape, (temporarily, for testing), and it worked! Ill go back through later and solder it on!
完成的
......and that's how it's done! Awesome. Glad you figured it out and got it working.
完成的
添加一条评论
添加你的答案
DJ Gunter 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 15
总计 542
