跳转到主内容
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
Is it possible to replace just ONE key?
Hi guys,
So for a while now my "M" key is broken on my Macbook Pro. It's typing fine, but the key comes lose every now and then. I have searched and searched but I can't seem to find a place where I can buy replacement keys. Is this something that's simply not available or am I looking in the wrong places?
Thanks for your help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Hmm, the plastic mechanism seems to be alright. I don't see anything broken off or anything like that, but it's clearly not "sticking" properly. So far I've had a hard time finding any replacement keys for the Macbook Pro. Seems like I would have to get the whole keyboard exchanged, which seems a bit excessive....
完成的
Thanks guys! I think I found a place to order my "M". : )
完成的
hi guys by cleaning my keyboard of my mac ,unfortunately i have broken the clips of "I" letter my question is ? isn't changeable or should replace all the keyboard and from where can i get it
完成的
添加一条评论
3个答案
已选择的解决方案
Here's a guide for the different type of Apple keys, select your keyboard and order the key: http://www.welovemacs.com/lakereke.html
这个答案有帮助吗?
得分 2
添加一条评论
Are you able to determine if it's the plastic mechanism that hold the key which is broken ? Or the part where the mechanism clips on the keyboard ? Or the part where the mechanism clips on the key?
If it's the plastic thing you may be able to find one on internet, I don't know if they are specific to mac or common to other brand. You can also get one from a dead keyboard, same thing for the key itself.
这个答案有帮助吗?
得分 1
添加一条评论
Yes, the key can be removed and you can replace the hinge too
The trick is to stick something that will not damage the key or scratch the casing and you can toss the bad hinge, keep the key
Put the hinge on how the old one came out in the key, and you will be fine
Put the key on, and you're done
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Franziska 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 713
