跳转到主内容
Televisions made by the Chinese multinational electronics company, TCL.
264 个问题 查看全部
Half of screen has no backlight
Only part of my TCL 65Q825 screen has no backlight. I'm assuming these local dimming zones are not working. What would be causing this? The TV is only about 1.5 years old and I would like to fix this if I can.
Thank you!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Chris Frasca this could be due to failed LED’s on the backlight strips. You will have to disassemble your TV right down to the panel. Then open up the panel and replace the strips. It’s a bit of a PITA but not to difficult. When you take teh panel apart you will come across a couple of “plastic” sheets. Those are diffusers, polarizers etc so do not mix them up, keep them in the same order and the same direction. Of course, you always want to check the power board output to the LED strips. Use a multimeter and measure the voltage on those. You should have the same voltage on each connection. Set your meter high since there should be a couple of 100’s volts on it. If you need more help with that, post some good pictures of all of your boards with your question. that way we can see what you see and hopefully help you a bit more. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
1条评论:
Tested all the lights they are all good ordered new boards will update when i get them.
完成的
添加一条评论
添加你的答案
Chris Frasca 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 73
