跳转到主内容
The Respironics BiPaP Vision is a respiratory ventilator (breathing assistance device) created by Respironics / Philips. Included is a mobile stand, various ventilator pieces that connect to the main device system, and a remote alarm. (Model Number: 582059)
Can it be used for CPAP
Can it be used for CPAP.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Tomasz Kosierkiewicz  no you cannot. The pressures delivered through BiPAP are different since it requires two separate pressures(IPAP and EPAP), whereas a CPAP does not have those and you cannot turn that off. If you feel your BiPAP is not working for you talk to your HCP for a different approach. Also, check your Respironics model number and make sure it is NOT involved in the recent recall. Check on here https://philipsrecalls.com/ Do not use it until you are sure that it is safe. Again, contact your HCP for assistance with this.
这个答案有帮助吗?
得分 1
添加一条评论
we legally can not give advice for medical equipment
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tomasz Kosierkiewicz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 250
