Smove mobile battery replacement
I need to replace the battery on my Smove Mobile gimble device it is a Howell 2x902360-1300mah 7.4v 9.62wh battery I need to find a suitable replacement either the same battery or an except-able replacement. I’m fine with soldering the terminals if I can find the same form factor battery.
3条评论
I am curious if you found a good solution for this?
由 Todd 完成的
@grayraver See oldturkey03's answer
由 Andrew S 完成的
How did you get the SMOVE apart? I have the same issue and want to bring mine back to life
由 Boppin-Jake 完成的
