跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Buds+ 真无线入耳式耳机的维修与拆解信息。于 2020 年 2 月发布。
Is there any HOPE?
I left my Galaxy Buds case with the earbuds inside in my pants pocket and washed them and then dried them as well. They still connect to my phone but the charging case is unresponsive after on the charger for 24 hours. Is there any HOPE???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
i would recommend disassembling the case and checking for water damage on the board and battery. if there is water damage attempt to replace the part. if not just dry it out, DO NOT USE RICE.
If that does not work you can either send it to samsung for them to investigate or you could possibly buy either a fake case from amazon linked below.. or you could buy a used case in good condition from ebay for your exact color if you want ti to resemble the original.
fake galaxy buds case
Hope this helped.
这个答案有帮助吗?
得分 1
添加一条评论
there is still moisture in the case. put it in a bag or container of instant rice for a week or 2. the rice with dry it out completely. than it should work again unless the battery in the case got damaged. you can buy these and replace it.
https://www.youtube.com/watch?v=StGaoAxv...
the numbers on the battery will help you order a new one normally $5-$10 with shipping from aliexpress.com
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sean Taylor 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 32
总计 3,308
