跳转到主内容
加入维修社区 - 创建账户
2019 年 9 月 20 日发布,这款 Apple 的主流 2019 款 iPhone 配备了 6.1 英寸 LCD 触摸屏、双摄像头,并提供六种颜色选择。它是 iPhone XR 的继任者。
3 mins Rebooting. Panic Full
panic(cpu 0 caller 0xfffffff02abe87e8): userspace watchdog timeout: no successful checkins from thermalmonitord since wake
service returned not alive with context : is_alive_func returned unhealthy : current fffffffffffc, mask 7fffffffffff, expected 7fffffffffff. SD: 0 BC: 1 Missing sensor(s): TG0B TG0V
service: backboardd,
What do i need to replace in this, it reboot after 2-3 mins but if it is not use i doesnt reboot.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
1个答案
已选择的解决方案
More than likely this is a charge port issue. Essentially the phone is expecting check ins from the thermal monitoring service and it’s not getting data from 2 of the sensors (TG0V and TG0B) So the phone shuts off.
It could be other things as well, but charge port is where I would start. TG0V I am sure is in that flex. TG0B is battery, and the signal for that may also be carried by the charge port.
这个答案有帮助吗?
得分 5
6条评论:
Sir why does also my iphone dont charge, and there is no battery percentage, also when i charge it, it only sound, but their is no charging, even it is connected.
完成的
@Altair Van Historillo Could be the same thing. If that cable is not working correctly, then it may not be charging the battery properly or reporting charge percentage. That's how the power from the charger is connected to the logic board.
完成的
i change the charging port cable but still booting up every 180 sec, also i still cant see the battery % not the battery health, and it is also stuck on 0%.
完成的
@Altair Van Historillo Could also be the battery itself, or the power button cable, which from what I've read elsewhere TG0V may also be in the power button flex cable. Although given the battery related symptoms, I am more likely to think battery.
完成的
Please is none of these it’s hardware issues go repair your power ic
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Altair Van Historillo 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 55
总计 18,378
