跳转到主内容
Wherever you go, bring some big beats with you. The SRS-XB10 is easy to carry and gives your music some extra bass.
9 个问题 查看全部
Replacement interior plastic brace/bracket with screw holes for XB12?
My Sony XB12 dropped and upon opening the outer shell you can see that the interior brackets snapped, everything else is okay and fully functional. Now the screws have nothing to screw on to and keep it closed, much less watertight.
Where can I find replacement brackets?
EDIT: both of the screw stems of the bracket, where the battery is attached, are capped and one of the mounting holes from the board bracket is obliterated while the other has three cracks and with any force will also split open.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@j053 . We would have to see what this all looks like. Looks like 2 of the screws go into extension “legs” from the battery case and two go onto some plastic fittings on the main board. We would have to see what this all looks like. Parts are not readily available so you would need to either purchase a broken speaker and harvest the parts from that or see if anybody can do some 3D printing for you.
Post some good pictures of where the crack is and which bracket you are referring to, with your QUESTION. 在已经存在的问题里加入图片 That way we can see what you see.
这个答案有帮助吗?
得分 1
1条评论:
I have updated with pics.
完成的
添加一条评论
添加你的答案
Jose Jimenez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 206
