跳转到主内容
加入维修社区 - 创建账户
iPod Classic 第六代。机型型号 A1238,80、120 或 160 GB 机械硬盘,黑色或银色金属前面板。
screen only shows www.apple.com/support/iPod
screen shows only an 'dead iPod' icon and the web address www.apple.com/support/ipod. Now tried to charge it and it just says 'very low battery' but not charging.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 28
添加一条评论
3个答案
已选择的解决方案
Jim, not quite sure which iPod you have, it does help if you can clarify that. Anyhow, MOST of the time, the "www.apple.com/support/iPod" error message will come up when the iPod has trouble with the hard drive. You can try and place your iPod in either diagnostic mode and run the test to see what it shows. You can also try to place it in disk mode and see if you can reformat or even access the drive. The low battery could be just that, a low battery that has been discharged below the threshold at which the iPod can charge it. I believe that to be 2.7 volts. A firewire charger usually can rectify that, sometimes even an AC adapter. My suggestion is to check your HDD first, and replace the battery. Worst case scenario, your logic board does not recognize the drive or the battery. Procedures and prices for the repair depend on your model of iPod.
这个答案有帮助吗?
得分 11
6条评论:
the show a circled x and the web site address
完成的
@willie johnson, same situation as above. Sounds like a bad hard drive or hard drive cable.
完成的
yes
完成的
@willie johnson yes it does
完成的
I get the same issue but it's ONLY the error message that displays.
I've tried the reset instructions yet still nothing.
It's an ipod classic 30GB 5th Generation I think and hasn't been switched on for at least a decade. Simply throw away?
完成的
显示更多的1条评论
添加一条评论
yes red x then error message
这个答案有帮助吗?
得分 0
添加一条评论
Use iTunes to restore …according to the IPod Classic
这个答案有帮助吗?
得分 0
1条评论:
please give instruction on how to use itunes to restore
完成的
添加一条评论
添加你的答案
Jim 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 22
过去 30 天: 82
总计 20,885
