跳转到主内容
Guides and repair information for televisions from Hitachi, a Japanese electronics manufacturer.
28 个问题 查看全部
My screen went super black mid show - Help!
My Hitachi 55 L6 was in the middle of Moana and just went black. Upon closer inspection we saw the screen was still there, just incredibly dark. The power and sound still work but it is just very dark. I am assuming there is some bulb or light that burnt out suddenly. Does anyone know what it may be? Is it worth it to try and get it fixed?
Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
The back light burnt out. but here is a video to help you make sure.
https://www.youtube.com/watch?v=7bOx-CVT...
完成的
添加一条评论
1个答案
最有帮助的答案
Stephen Wirthlin  verify your complete model number. If your pictures is still visible by shining a flashlight at an angle against the screen, that would mean you lost your backlight. Remove the back cover from your TV and check the power board backlight LED connections. You can check those with a multimeter and let us know what voltages you get. If those are acceptable voltages you will have to replace the backlight strip. Now this is what we need to know the exact model of your TV. With that we can determine if they are edgelit or if it is a backlight array that is needed. The replacement of the :LED backlights are essentially the same for most of the panels, so the link previously provided in the comments will give you a good idea about what is needed.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Stephen Wirthlin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 58
