跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
Charger port iPod touch 4
Hello everyone, how to replace the charger port on the Ipod touch 4?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
i have the same problem but whats wierd is that if i plug the charger in it reboots from completely dead and then doesnt charge and shuts off cause there is no power
完成的
添加一条评论
7个答案
最有帮助的答案
You will of course have to totally disassemble the iPod. The dock connector is solder onto the board. You will have to do lots of soldering. You will have to un-solder two anchors and about 30 connections, they are very small and close to each other. So you have to take extra care not to shorten the pins out. After that you will have to resolder all those connections and the two anchors. Not an easy task, unless you are used to soldering small pieces. This video is not for a 4th gen but will give you an idea what you are up against. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
Actually there's a very simple way to remove the old connector you using A heat gun. You can pick one up for about 25 or 30 bucks at a hardware store. Disassemble your motherboard from the rest of the iPod put it in a clamp and use the heat gun on that connector back and forth on the metal parts in the connector. When it gets hot enough, the solder will melt and the connector will kind of droop. When it does that, Tap lightly with a screwdriver and it'll fall right out.
这个答案有帮助吗?
得分 1
添加一条评论
You have to remove the old by desoldering the two screw holes with a desoldering iron and bend slightly. Turn board over and with a heat gun with a small tip evenly heat the 30 pin connector until solder has liquified. hold with a pair of pliers gently pull it away from board while moving heat back and forth over. make sure to protect other components from heat with heat resistant tape or aluminum foil. Reattach the the two screw holes with solder and then align all pins to correspond with the 30 pins on board. Turn board back over and resolder using a heat gun and solder paste or using solder and a iron. Check for any bridging before completing.
这个答案有帮助吗?
得分 0
添加一条评论
Will a charging pad work to fix this?
这个答案有帮助吗?
得分 0
添加一条评论
:( It's happend to mine the charger port is like chipped i tried to charge it, it was charging suddenly it stopped and came off
这个答案有帮助吗?
得分 0
添加一条评论
hello ive jus dropped my ipod n the place where you put the charger in is broken, could you help me!?
这个答案有帮助吗?
得分 0
添加一条评论
hi would you be able to fix my charging port or replace it on my i pod touch 4th generttion and if so how much would it cost me.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
andrewbezn 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 11
总计 23,395
