跳转到主内容
加入维修社区 - 创建账户
The Ford Explorer and the Mercury Mountaineer were both updated for the 2006 model year on a new frame, produced by Magna International rather than Tower Automotive.
AC only blowing heat
My blend door actuator started clicking and was stuck on AC. I finally just replaced the actuator and now I have heat but I now only have heat. No matter what I set the temp setting to it just blows hot air out of all the vents on both sides, driver and passenger.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
i have ford explorer model 2010. same issue of no cold air blowing
checked and found compressor clutch relay not energizing. while jumping he clutch relay contact ,compressor clutch engaging. seems some control logic blocking the signal to compressor clutch relay. anyone can suggest what are the signals blocking the compressor clutch from engaging?
完成的
添加一条评论
1个答案
I would guess that there is still a problem with the blend door.
If it were “clicking” I would think the actuator was attempting to move the door, but something was wrong with the drive.
Or it could be that the actuator did not get installed properly.
这个答案有帮助吗?
得分 0
2条评论:
My only guess is there is something wrong with the new actuator. My setting was already set on cold so it started blowing hot before I messed with it. I’m not sure how it could be installed incorrectly. There is only one plug and the shaft only fits in one way.
完成的
Did you fixed the issue? Because I’m having the problem too
完成的
添加一条评论
添加你的答案
Scot Williams 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 63
总计 1,242
