跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for televisions manufactured by Panasonic.
3 blinking red led fault code
Panasonic TX-P42X60B
I am trying to get the panel for this TV as I think it is the power panel that is fault
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@electric151 the 3 blink code for your TV model is most commonly caused by a bad A-board. That is your main board. Of course, the 3 blink code is not listed anywhere. So, it’s a bit of a gamble. I’d check the power board output to the A-board on the connector. Check to ensure all voltages are present as listed on the print on the board. IF they are, then you pretty much should try to replace the A-board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alistair Dunn 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 5
总计 134
