跳转到主内容
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428 个问题 查看全部
Resistors and capacitors vaules around power supply part?
Hi everyone!
So i got xbox one S form friend. Xbox was flooded by a cat urine :C. a lot of rezistors and capacitors around power supply part are just very very rusty. I need to know values ALL of them to buy new ones.
Btw i know that this “fix” is probably not worth it so please do not write anything like": “let this console die” or “it’s not worth , buy new one”
Thanks for help!
Update (10/29/2021)
@oldturkey03
I send more pictures after more detailed cleaning
Update (10/30/2021)
And parts that i think are good to replace:
https://pl.aliexpress.com/item/400032469...
https://pl.aliexpress.com/item/330014307...
https://pl.aliexpress.com/item/329611170...
Update (10/30/2021)
So i unsolder memory(i guess it’s memory and it looks just fine. Now it’s time to clean it up and solder it back. Wish me luck
Sorry for bad quality of pictures, my phone camera isn’t as good as my canon
Update (21/11/2021)
Here I enclose some pictures. I need to buy sd card adapter. For this moment i just took photo of my microscope LCD :]
This one is ok
Here’s are this “3” pads that become “1”
Update (23/11/2021)
https://pl.aliexpress.com/item/330546860...
https://pl.aliexpress.com/item/329344270...
https://pl.aliexpress.com/item/100500258...
Update (27/11/2021)
C915
R9C29
R9C30
R9C22
R9C31
R9D5
R9D8
C9C19
R9C19
C9D18
R9D25
R9D26
R9D29
R9D17
R9D30
C9D17
R9D20
C9D8
C9D11
C913
C9C3
C9B5
C9B2
C9B7
C9C5
Update (5/12/2021)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
19条评论
Can you give us the model and revision number of your power supply?
R9D33: 2.2 ohms
R9E3: 1 Ohm
完成的
@andrewsawesome model N15-120P1A rev 03 , just to be clear it is NOT part of the power supply exactly but the part of mainboard where pins of the power supply goes :V. And thanks fore the respond ane values <3
完成的
@werfex clean your board with some 96%+ isopropyl alcohol and a soft brush first. Of course, best way of cleaning that particular board would be with an ultrasonic cleaner, but if you do not have that use the aforementioned method. Then post a picture of that clean board with your QUESTION as well. You really have to narrow it down otherwise you will be looking at an extensive repair and most likely could get a replacement board for lot less time/money. But lets see what we can find out about all of this once its clean.
完成的
I agree with the above comment, clean the board very well and see how things look then. Out of those components the most likely to be bad is the small chip just above the rusty capacitors in your pic.
完成的
@oldturkey03 so to be honest, it was already cleaned, it is still dirty on pictures bc it is just very old, i mean my firend left it for ONE YEAR, I probably need to use hot air to remove this mess(yes i used isopropyl). My question is very difficult i guess bc i need values of all capactiors and all rezistors in this area. Microsoft didn't share schematics of this console so i have no chooice.
完成的
显示更多的14条评论
添加一条评论
2个答案
最有帮助的答案
@werfex so I have to break it into smaller pieces. I will add to this answer with every “block” I identified. Components that are marked as “desolder” cannot be measure in circuit and will have to come off. So you will have to bear with me on those.
Also, the components are identical on the next two divided sections so I did not list them separately
Capacitor C9D19 8.3uF
Capacitor C9D20 9.22uF
Capacitor C9D21 1uF
Resistor R9D33 2.2 Ohm
Capacitor C9D22 96nF
IC U9D2 AZ6 Dual MOSFET Gate Driver
Resistor R9D32 2.2 Ohm
Transistor Q9D3 4C55N Mosfet
Transistor Q9D2 4C50 RJ31 MOSFET
Resistor R9D31 1.1 Ohm
Capacitor C9D18 1nF
All values are measured so assume a minimum 10% tolerance
….and on the other side is IC U9C2 NCP4205 PMIC VOLTAGE REGULATOR since it looks like you already removed it
Update 01/14/2022
Q8D1 G22 transistor in SOT023 package
C9D7 120µF 0805 package
C9D11 1000pF 0603 package
C9D5 120µF 0805 package
Q9D1 MOSFET 7409 GV7 X1E (NTTFS4928N)
C9C21 0.15µf 0603 package
C9C20 38Pf 0805 package
R9C24 50ohm 0402 package
C9C19 45pF 0603 package
R9D15 50ohm 0402 package
R9D14 50ohm 0402 package
R9D17
C9D16 35pF 0603 package
R9D19
C9D10 35pF 0402 package
这个答案有帮助吗?
得分 2
15条评论:
Hi! Sorry for the late answer! Unfortunately, as I said, I can only work on the weekend at the console, but when friday comes i'm going to solder all new capactiors and check if mosfets still works. Thank you very much for help!!! It is for me very impressive!!!.
完成的
Hi!
So i have checked mosfets and all of them are fine except one. If my knowledge about mosfets is good , n-channel type shouldn't has current flow through Source and Drain. One of 4C50 has this issue.
Next thing, three solder pads of the one mosfet "become" one(more on pictures in update). I mean there is 3 sources and one gate pin but im not sure if it is a problem or not.
Next thing, are you sure C9D21 is 400uF? I can't even find it to buy, biggest one that i have is 10uF, and one the site with electronic (www.tme.eu) the bigest smd capacitor is 220uF.
Last thing, there is lot of capactiors and resistors that just "have disappeared". I guess they "escaped" when i was working not carefully with hot air. Is it possible later when we're done with this part of motherboard to find values of this components?
Again sorry for being lazy. looks like this project is going to take longer than i expected. waiting for parts delivery from aliexpress etc. can make it several week.
Thanks and wish you a good day!
完成的
@werfex I will double check on C9D21 just to make sure. I have to desolder those caps since my ESR meter disappeared. So, the values I get are with he components out of the circuit:-) I will also check on Q9D4. Yes, I hear you about the disappearing components while using a hot air station :-) I lose that all the time and am now using mainly a soldering iron for removal. We can get those values at a later time for as long as you still have the reference designator printed on your board, we'll be okay.
完成的
@werfex C9D21 is actually 1uF. Wrong scale on the meter will do this ;-)
完成的
@oldturkey03 (one fast thing, i tried to reply yesterday but my comment was treated like spam 3 times beacuse of alliexpres links so i hope now it is gonna works, oh and ali link are in the update!)
Oh okie dokie! unfortunately, school again so I have to wait until Friday to repair. Returning to this missing elements. There are still very good visible signs of them so thats good info. One last thing. I need to reball 4 of memory. I tried to put 0.6 metal balls with tweezers but it's almost impossible to me. Should i buy one of this plates?
{LINKS INE THE UPDATE}
I know they are compatible with PS4 but xbox one S has ddr3 ram too so maybe they are ok for this "operation"
Thank you for help and wish you good day!
完成的
显示更多的10条评论
添加一条评论
How did it turn out? Ive worked on alot of originals and 360s but only a few ones.best was y to learn is roll back those sleeves and dive into it
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Paweł Ordowski 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 57
总计 3,040
