跳转到主内容
The Motorola Moto Z3 Play was released in June of 2018. It has a 6 inch screen and a non-removable Li-Ion 3000 mAh battery. Its rear camera is 12MP and its front camera is 8MP. Model number XT1929-3, XT1929-4 and XT1929-8. "XT1929-3 NA XT1929-4 NA XT1929-4 NA XT1929-5 LATAM XT1929-6 LATAM XT1929-8 EMEA/APAC"
14 个问题 查看全部
Repair connector on z3 play
Was replacing crack screen and tested by inserting ribbon in connector and it worked. When I took off to apply adhesive I broke piece off on connector and now it will not work. Am I able to replace connector on motherboard?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@micbob4 that is Motorola connector 09014221001W which is a CONN,ZIF, 61 PIN,0.9MM HIGH, 13.8 LONG. The only online connection I can find is on here You can of course try to match it with something that mouser.com or digikey.com may have. Also, you can always try and purchase a broken circuit board for the same model phone and use that to harvest the connector from.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Robert kidd 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 131
