跳转到主内容
Guides for the Wi-Fi version of the iPad mini 5—model A2133. Released in March 2019, the iPad mini 5 is the successor to the iPad mini 4.
11 个问题 查看全部
I need a Permanently remove iCloud Activation lock
Hi,
if it’s ok on here to ask this for a iPad I legally own. I need to find someone who I can pay to do a permanent removal of a iCloud activation lock on a iPad mini 5, ‘Wi-Fi only’ can anyone recommend to me who I should contact to get this done?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
so you own it but its locked with somebody else's applid and password ?
完成的
添加一条评论
2个答案
最有帮助的答案
Well, it’s easy for technician to remove icloud of IPad that is Wifi Only, by removing the hardware or from the software. You can ask it to technician iPhone that can remove icloud to remove it. But beware of scam, even though it’s easy to know which is a scam or not for those who know the basic process of removing iCloud by a paid tool, or Bypassing iCloud, because usually they scammers don’t even know the proccess of jailbreaking (the most basic of removing iCloud), and so on, but some people still get scammed.
So, the conclusion, yes you can ask the technician to remove iCloud, as long as you are the legally real owner, and can differentiate which is scam or not.
这个答案有帮助吗?
得分 1
1条评论:
For this model or any ipad with A12 CPU . Hardware metode is not possible. If you change the SN and WIFI address on these models . You cannot active it . It will stuck on activation(Unable to activate, Error ) because of the new CPU design. It doesn't matter if it is wifi only or cellular.
完成的
添加一条评论
I removed iCloud i pad mini 5 help me
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gary 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 62
总计 1,666
