跳转到主内容
加入维修社区 - 创建账户
发布于2017年7月28日,新 Nintendo 2DS XL 是 Nintendo 2DS 掌上游戏机的迭代机型。
Flashing Power LED - Not what you think...
My New Nintendo 2DS XL power LED flashes red as if the battery is about to run out, and shows the battery icon on the home screen with a single bar of power left.
The battery is not actually about to go flat though. Regardless of how much charge the battery has, the 2DS XL thinks it is about to go flat. I can play for hours with it flashing and it will be fine but I will have no idea when it might actually run out of battery, so realistically it can only be played while charging.
I can very temporarily fix the issue by letting the buttery run completely dry and then charge the battery. When I turn it on it will have a blue light and proper charge, but at some point goes back to flashing.
Would replacing the battery fix this, or is it more likely a connector or something else?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Just realized I never came back with closure.
I opened up the case and painfully removed the battery (2DS XL batteries are "not replaceable") and put it back in. That's all it took for the battery to work properly. I've been using it a bunch these past 2 years and it has behaved correctly ever since.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
@fliggle_slaps start with a new battery. It sounds like there are issues with the “Gas Gauge”. Even if the battery does not resolve it at least you have a known-well starting point should further troubleshooting be needed. 任天堂 New 2DS XL 电池更换
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Fliggle_Slaps 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 39
总计 1,581
