Need to ID usb1 micro board on NOCO battery booster
I have NOCO GB40 1000w battery booster. The micro USB is damaged and I desoldered the USB 6 pin board but cannot find a replacement. The id numbers on the board are ***pt2064b2 20150429 / an-1406003lf Help!!
3条评论
Je veux acheter là pièces
由 va2rok 完成的
I had success in buying Uxcell a13081900ux0118 5 Pcs Micro USB Type B Female Socket 180 Degree 5-Pin SMD SMT Jack Connector (Pack of 5) on amazon. Desoldering the old plug and carefully fluxing and soldering on the new one. Took me 3 tries to get it right. That being said, I would also like to track this down as it is easier to solder in.
由 TimE 完成的
Can you replace the USB micro with a type C version? If able can I use a vapes type c port for this board type?
由 Heaven_x_hell 完成的
