跳转到主内容
The Samsung Galaxy A10 is an android smartphone developed by Samsung Electronics. It was released in March 2019.
68 个问题 查看全部
What are these parts on motherboard?
After water damage, I replaced the LCD and the battery. The phone seems to work perfectly, but there are two metallic shields on the motherboard that get hot when the phone is turned on, but in standby. I want to soak it in isopropyl alcohol, but I am curious what are those metallic shields covering? Do I have to remove them to have better access?
Link for an image that shows the metallic shields: https://vrm24.com/media/Motherboard_2_Z0...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@forzal those are EMI shields. They are usually desoldered. You can use a hot air station or a very large tip on your soldering iron to do so. Of course you can always use some cutting instruments like some sharp scissor. Check videos like this to get an idea how its done.
这个答案有帮助吗?
得分 3
1条评论:
Thank you very much!
完成的
添加一条评论
添加你的答案
Laszlo Attila 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 55
