跳转到主内容
Repair guides and support for the eighth generation of Ford F-Series trucks: the F-150, F-250, F-350, and F-Super Duty.
58 个问题 查看全部
A hose connected just below the oil filler cap
1991 F-350 7.5L 460.
This hose connected just below the oil filler disconnected from wherever the other end connects to. The loose hose knocked the drive belt off and leaked motor oil. I went ahead and replaced the drive belt, but I’m embarrassed I can’t figure out where the other end of this hose connects too.
The hose is about 1/2” diameter with a plastic section on the end that and connects just under the oil refill cap on the neck.
Update (10/13/2021)
The hose on the top edge of the oil fill cap. Other pic is the other end of the hose and the connection
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Please post a picture of where it connects to, and the hose itself. Trying to see exactly what it is you're talking about to make sure.
完成的
@brandon_k banging my head against the wall. Doesn't seem to be connected to anything and I can't find any reference to it in other forums.
完成的
@dw9976 answer posted below. From what I've found, I agree with it.
完成的
添加一条评论
1个答案
最有帮助的答案
@dw9976 that should be the crankcase breather. It goes to the air cleaner box, under the large throttle air intakes.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
D. Williams 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 35
总计 1,272
