跳转到主内容
Repair guides and support for your LG TV.
1350 个问题 查看全部
LG 65UK7550 TV weird glitches and restarts
Hello,
I have problem with my LG TV - LG 65UK7550. It suddenly starts glitching weirdly as you can see in the video. Restoring to factory settings did not help. The image in the movies is fine without any problems, but user interface is glitching and sometimes unresponsive. After a while, it even restarts randomly, and from today it started to take a long time to turn on. Do you think there is a problem with the motherboard or may it be elsewhere?
Thank you very much for every answer
Update (10/27/2021)
For a long time I could not find a compatible board on the local market. I finally found this, but the connectors have a slightly different design than connectors on my board. Will it be compatible? Thank you
(photo of my board is on the left site, everything else on the board seems to be the same)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Andrej Pracovný účet  that is one interesting error. The way I see it and can judge by your video, this is either a main board error or a LCD panel error (unlikely). Schematics for your main board are not to be found so you would need to replace it to see if that fixes it. If it does not you will have to dig deeper into the panel driver and see if there is anything that has failed. Schematics for that board are not to be had so this could lead to having to replace the screen (again, unlikely but there is always the chance). Go with the main board for now and let us know what you find.
这个答案有帮助吗?
得分 2
6条评论:
Thank you, I'll try to find used mainboard from damaged TV and buy it, but do you think it is more probable to be a mainboard error or a screen error?
完成的
I thought about the screen error and that would be the most unusual error because of the way it moves and closes the gaps again etc. If anything on the screen, it could be the board but I have not seen it go in those weird directions. Like you said, it is okay during movies and does not show this. This here "restarts randomly, and from today it started to take a long time to turn on" could be the main board.I would try a main board and see if that fixes it. I would think that the user interface data etc. is probably on an eeprom on that board. I am trying to find more information about this from my manuals but have not been successful yet.
完成的
完成的
I know that this is an old issue, but after a year I was a few months ago finaly able to buy a new logicboard and now my TV works (for a few months now) without any issues. I write this just so if anybody else has the same issue.
完成的
@Andrej Pracovný účet Awesome. Thank you for coming back and letting us know. glad your TV works again.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Andrej Pracovný účet 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 200
