跳转到主内容
2008 netbook; Model ZG5 AOA150-1691; 8.5" screen; 1.6 GHz N270 Intel Atom Processor
74 个问题 查看全部
Can I solder the power supply pin connector inside my acer aspire?
The pin that the power supply attaches to seems to be wiggling. I can only get flashes of connection. I think the pin is loose and needs to be resoldered inside the case. Is there any alternate way to fix it? Can I solder this myself (reach the necessary area) if I disassemble the unit?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Lizz Driscoll, I would think that you should be capable of soldering the DC connector into the board. (if you know how to solder). If not then I would get an old logic board first and practice first. There are some guides like this, on here. Here is a guide that will show you how to dismantle and here is the part that you need. Good luck and let us know if you need any help ;-)
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Lizz Driscoll 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 951
