跳转到主内容
加入维修社区 - 创建账户
第四代 iPhone CDMA 版的维修指南。型号 A1349,有8,16,以及32 GB 存储空间的选项。
Logic Board Rubber Bumper Location?
I replaced the display assembly this weekend, but when I was attempting to reinstall the logic board (step 21 of the guide, in reverse), a small rubber bumper came loose from 'somewhere' on the board (I think).
Here's a picture of the bumper (with the broken screen as a backdrop to give you a sense of proportion). Can somebody identify where it belongs? It's seldom good when you've got parts left over!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
已选择的解决方案
It goes on top of the Logic Board, under the two Front Screen Flex Cables. I have seen a couple of iPhone 4 without this installed or just missing and they functioned perfectly.
这个答案有帮助吗?
得分 8
2条评论:
That did it!
完成的
That was a huge help. Thanks!
完成的
添加一条评论
Also, notice there is a thick and thin side to the bumper, and the thin side should be on top, or toward the back panel.
这个答案有帮助吗?
得分 2
添加一条评论
That little plastic bumper folds over the top of the logic board assembly where the Digitizer ( Front Panel) cables come up and over. If you look close at the bumper there is a small grove that is the same size as the boards thickness. Its just there to protect the Digitizer's cables from the rough surface of the logic board.
这个答案有帮助吗?
得分 2
1条评论:
Thanks for that info... Super helpful
完成的
添加一条评论
what would happen if you were to put this on the wrong way
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Matt Strange 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 38
总计 7,726
