跳转到主内容
加入维修社区 - 创建账户
Swift 3 轻薄时尚,是移动办公的理想笔记本电脑。它配备最新的 NVIDIA® GPU 和 Intel® CPU,电池续航时间长。机身提供多种显示屏选择:一款是配有 13.5 英寸 3:2 比例 2256x1504 IPS VertiView 显示屏的银色优雅机身,另一款是色彩生动的 14 英寸 16:9 FHD IPS 显示屏。
Tips on opening back panel
I own an acer swift 3 SF314-55g and it has an annoying back panel to open as its too tight and there are no gaps to work with. Is there a trick to opening it or is it not even design to be opened?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
My Swift 1 has the same problem. I just used a jimmy and worked my way up in size until I could fit a pick in there. Then I worked the pick around the border undoing the clips holding the backplate in place.
由完成的
添加一条评论
2个答案
最有帮助的答案
Just remove all 10 screws. Don’t worry because there are no cables attached to the panel so you can simply remove the back panel.
这个答案有帮助吗?
得分 3
添加一条评论
It takes a lot of prying but once you get something in the gap it is easy from there.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Clement Chang Cheng 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 53
总计 2,645
