跳转到主内容
The Razer Blade Stealth is a gaming laptop with a 13.3 inch wide screen. The laptop features 16 GB of RAM and an Intel Core i7 CPU. It comes in Space Grey and Mercury White.
3 个问题 查看全部
New battery only works while plugged in
I just replaced my battery in my razer blade stealth and it works fine while plugged in but says charging and stuck at 97% and when I unplug it it turns off immediately and won't turn on while unplugged. The battery is brand new. The old one was fairly bloated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
3条评论
does the laptop power on without a battery?
完成的
@logixal yea it will power on without the battery connected
完成的
Exact same problem!
完成的
添加一条评论
1个答案
最有帮助的答案
@riveteer I am certain you double-checked your work and made sure that your connectors are all properly seated and that there are no issues like bend pins etc. with those. I would contact the seller and replace the battery once more just to rule it out as the culprit.
这个答案有帮助吗?
得分 1
1条评论:
Yea thanks. I did look around more today and was looking at the connector for the original battery and the one I bought from ifixit had a poor connector. I bought another and plan on returning the one I got. Thanks
完成的
添加一条评论
添加你的答案
Jack Kuckhahn 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 15
总计 706
