跳转到主内容
加入维修社区 - 创建账户
Nikon D300 于 2007 年 8 月 23 日发布,是由尼康公司 (Nikon Corporation) 生产的一款 1230 万像素半专业级 DX 格式数码单反相机。
Error code F EE
After sitting unused for 4 to5 years camera does not shoot or display speed and aperture.
Code F EE flashes in upper right area of display
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
hi @bkdan
what I have found is you need to ensure that the lens is attached to the camera correctly. This error message will appear if the lens is not attached correctly to the camera or if you are not using a CPU lens Alternatively, if the lens has an aperture ring, it may not be set to f22 (or the highest aperture number on the aperture ring - normally marked in orange). Select the aperture number marked in orange on the lens and lock it using the aperture locking switch to prevent this occurring again.
Set to F22, or the highest aperture number normally marked in orange. Note the locking switch.
If the above did not resolve the problem and you still experience the error display FEE, in this case, you may need to return your equipment for service. Before doing so please also check the following.
Check that the EE servo coupling highlighted on the lens has not been broken.
Check that the F-min switch highlighted on the camera body has not been broken.
这个答案有帮助吗?
得分 1
2条评论:
here is also a link to a service manual for your camera
https://www.manualslib.com/manual/857500...
由完成的 分享
I am a novice photographer and just bought a used Nikon D300 and was having the same issue. Changing it to the highest apperture removed the " Fee" error and allowed the shutter button to depress but it also stops the AF lens from autofocusing???
由完成的 分享
添加一条评论
添加你的答案
Dan Avallone 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 66
总计 4,784
