跳转到主内容
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
263 个问题 查看全部
Mild Nintendo DSi water damage
So recently I had my DSi in my backpack and in the other half there was a water bottle that snapped open. The DSi wasn’t very wet at first so I thought nothing of it, until I turned it on. So, first the bottem screen flashed and the blue light went on, and then turned off. I tried this a few times, and one time, it actually turned on. It got to the home screen for a bit until it turned off again. The bottom screen didn’t work, even though it was the one that flashed. I took the battery out soon after, and indeed the water indicator was pink and there was mild water on the battery. I have seen a few solutions to this, such as cleaning it with alcohol, but I’m not sure it works with mine.
So, what can be the solution to this fix?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @gorfalf ,
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the game console’s operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your console and then remove the battery as soon as possible from the console to minimize any further damage.
Then you need to dis-assemble the rest of the console and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this it might possibly work correctly again.
Here’s the ifixit Nintendo DSi guides which may help.
If this process seems too daunting, take your console to a reputable, professional electronics repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Your mom 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 9
总计 272
