bottom of screen wont respond
ok so i bought a glass digitizer from ebay and i put it on my 3gs and installed everything correctly and now when i turn it the bottom of the screen is not responding but the rest of the screen is please help.
Christian, it has been my experience that when the touch screen functions only partially, and if there are dead spots on it, that it is the screen that is not working properly. It appears that over the last couple of weeks we see an increase in only partially functioning screens. Of course, check your connections, make sure they are all seated properly and make sure that you have the right parts. If you can verify all connectors in good working order, all connections properly seated, no corrosion or debris present, I would contact the vendor and get another digitizer. Try a reset of your iPhone as well. Good Luck.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 541
1条评论
i tried everything u told me and now my lcd got messed up so got to order the parts from amazon
here is the link to the product http://www.amazon.com/Digitizer-Adhesive...
is it compatible or should i find something better
also i sent a message to the seller that the product was defected the he said that i have to pay for shipping and handling which would cost more than the product itself
由 Christian 完成的
