跳转到主内容
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
597 个问题 查看全部
Panic after changing battery
Got a battery kit for iFixIt, and it seemed everything worked just fine, no problem during the swap.
But when booting, now macOS panics after a while, and the Windows partition that was there too boots fine but with quite a few video artifacts. It makes me think macOS panis when switching to the graphics card but not really sure.
I had a USB key with VMware ESXi on it and that one boots just fine, I don’t think it’s using the graphics drivers at all.
Booting lid closed on an external monitor has the same symptoms.
Any ideas ?
[EDIT] Tried resetting NVRAM and SMC without success
Update (09/02/2021)
Here is a snap of the last line before crash
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
What do you see in the crash log?
Also did you try running diagnostics?
完成的
Updated question. Thanks !
完成的
添加一条评论
2个答案
最有帮助的答案
Have you tried resetting the NVRAM / PRAM? This could solve the issue, but be aware that it also resets some minor preferences (see last bullets in the link).
If you suspect the graphics card to be the culprit, do you have a dedicated graphics card and are you running some kind of CUDA drivers? They might get reset as well so make sure you are using the most recent drivers depending on your OS. BTW, which MacOS version are you running?
这个答案有帮助吗?
得分 1
1条评论:
Thanks Tobias. Yes, NVRAM and SMC have been reset. That's a vanilla install of macOS 10, the latest supported by this machine (10.15).
The recovery boot also seems to stall but not always panics.
完成的
添加一条评论
It appears the NTFS volume has a corruption! You’ll need to boot up under macOS and make sure the GUID volumes are in good order using Disk Utility. Then reboot under Windows and use Disk Management to repair the NTFS volume.
这个答案有帮助吗?
得分 0
1条评论:
Thanks, that's probably not related though. By then WindowServer should have started and graphical UI be up. NTFS issue is probably normal as the Windows boot we tested was shut down abruptly.
Thanks
完成的
添加一条评论
添加你的答案
yann 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 70
