跳转到主内容
加入维修社区 - 创建账户
Sony WH-1000XM2 无线降噪包耳式耳机的维修与拆解信息。
Left speaker not working
Hi,
My left speaker stopped working. Touch is still working on the left side, right speaker works fine.
Can anyone advise which cables I should check/replace and Mark them in the attached image?
I have opened up the headphones.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Does the left speaker not work on wired mode(3.5mm cable), wireless mode(Bluetooth), or both?
由完成的 分享
It doesn't work wired and unwired
由完成的 分享
Hello,
Had the same issue with left speaker no longer working (after crackling for a few weeks),
The continuity of the wires was OK, however there is no continuity in the speaker itself once disconnected from the electronic board.
Do you know where to find a replacement speaker for hw-1000m2 ?
由完成的 分享
添加一条评论
2个答案
最有帮助的答案
This sounds like a connection problem or a bad speaker. Can you take the circuit board and any protecting plastic off the left speaker cup?
这个答案有帮助吗?
得分 1
3条评论:
I should be able to do that. What should I look out for?
由完成的 分享
@mrvolcan Make sure there are 2 wires connected from the speaker to the board. Make sure both of the wires have continuity from one side to the other. If both of those pass, comment both checks passed.
由完成的 分享
I have the exact same problem. This evening the left speaker if my sony wh-1000xm2 decided to stop working. I don't know what to do.
由完成的 分享
添加一条评论
I assume it is an connection problem between the pcbs on both sides. I have the same problem now with my headphones. I seems like there is no signal for the left driver. Anybody figured out the problem?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Moritz 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 50
总计 2,075
