跳转到主内容
加入维修社区 - 创建账户
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
MacBook Pro's screen turns grainy, flickers and turns black
I recently received this macbook from a relative which seemed to work without a problem but recently, when turning on the laptop the screen would look grainy then after a while it would flicker and finally some parts of the screen would just be black. I tried the Apple Diagnostics (pressing D at the start) but it didn’t mention any issue. I also tried formatting my HDD from Internet Recovery and still nothing, also to mention that during the diagnostics and recovery the screen issue didn’t happen. I finally tried booting up in safe mode and it seemed to work but when i booted it normally the problem persisted.
Here is a video of the problem: https://youtu.be/bBTXtjmlfbs
I really don’t understand what the problem is, I would really appreciate some help. Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Does an external display look OK connected to the Thunderbolt port (mDP or TB display or via a HDMI/VGA adapter)
完成的
what Dan said.if external display work, then it's the panel. if so, open the case try reseating the lcd, check the pin for corrosion or bent pins.
if the external display doesn't work then it's the motherboard or gpu issue.
完成的
I just tried it with an external display, it shows the same issues as the laptop's screen.
In this case does it mean that it's a motherboard issue? Is there a way to fix it?
完成的
I maybe the RAM
完成的
添加一条评论
1个答案
已选择的解决方案
Ouch! Sadly thats the sounds like the CPU thats failed you! This series uses the intergraded graphics engine within the Intel chips HD Graphics 4000.
You could try replacing the RAM as this series leverages it for the video RAM. But given the symptoms I don’t think that will help (204-pin PC3-12800 (1600 MHz) DDR3 SO-DIMM) support for upto 16GB MacBook Pro 13" Unibody 中期 2012 RAM内存条更换。
You’ll need a new logic board MacBook Pro 13" Unibody 2012末主板更换
MacBook Pro 13" Unibody Mid 2012 主板图片
指南
难度:
困难
45 minutes - 1 hour
MacBook Pro 13" Unibody Mid 2012 RAM 内存条图片
指南
难度:
简单
15 - 30 minutes
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marcelo Marquez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 175
